Hi expert,
I’m having a problem to merge 3 dimensions. This is because the fields are not exactly come from data provider. I have 2 fields :
a) L01 Month Name (This is from data provider)
Jan, Feb , Mar, Apr, May Jun, July, Aug, Sept, Oct, Nov, Dec
b) Average Yearly (dimension variable created in webi)
c) Average 1st Half (dimension variable created in webi)
I want to merge this 3 dimensions into 1 variable which expected like :
Jan, Feb , Mar, Apr, May Jun, Average 1st Half,July, Aug, Sept, Oct, Nov, Dec, Average Yearly
Do you any have any ideas on how to merging those objects because this is my bottleneck to complete my reports.
Thanks & Regards,
-Syahida-
norsyahida.saadon (BOB member since 2011-07-11)
