Do merge dimensions work when published as a web service?
Vin
vinr (BOB member since 2013-07-18)
Vin
Welcome to B:bob:B!
Merged dimensions are not published as a web service. What is published as a web service is a data block. How a data block is created - either using merged dimensions or not - is transparent for a BI service.
I have a data block which is having a merged dimension field.
The report runs fine in webi rich client but when i publish this report block and test it i dont say any data returning from the server.
Are there any limitations ?
no there are no limitations.
what are you doing to Test ?
did you drop a spreadsheet component on the area where you are binding to in Xcelsius ?
Also consider scheduling your webi so it has an instance.
config the xcelsius web service to use the instance.
Cairmor (BOB member since 2008-06-05)
