Merge data from diferrent universes
Hi Ronen,
It is no problem to combine multiple universes in one report, as long as
there is a ‘key’ column by which you can “link” the queries. To link two
queries go to the dataprovider dialog and select an object. Then apply
the link by selecting the details tab and press the link button. You
then should be able to choose the object of the other query.
Hope this helps.
hans
Do you know of a way of combining data from different universes, for
example: if I have an employee universe with employees personal
attributes,
and a universe with employees professional attributes and I want to
get
attributes from both universes on an employees sectioned by their
groups and
in the same report.
