Can any body please help me out in searching for Merge cells property in Deski XI R2.
Thanks in advance.
Swati .
swathi padithala (BOB member since 2008-12-26)
Thanks in advance.
Swati .
You need to Format the cells as per your requirement.I think there is no option available to merge the cells in Desk I.
Thanks!
Prince. (BOB member since 2009-11-17)
Hey Prince, welcome to B:bob:B!
@Swati, tell us what exactly you need. If suppose you need in one cell to be merged with in another cell, instead of having them both in separate and trying with formatting stuff, you can just have them together using concatenation.
=<Name>+" "+<Emp Id>
Jansi (BOB member since 2008-05-12)
Hi Jansi,
I had to go through a typical format not to concatinate the words, i need the merge cells property as, which is available in Webi.
Thanks & Regards,
Swati.
