Maximum waiting time of 7,200 seconds exceeded
Did anyone ever have below error when extracting from SAP ECC using extractor? It was coming from the error log of any scheduled job to be ran at 5:00am.
In addition, if there anywhere list all data servies error and its explanation? Eg, VAL-030977, does SAP provide the detail documentation on the error and possible fixes?
Job name: Job_SAP_0FI_AP_4_Delta
(14.0) 07-29-12 07:26:10 (E) (96224:94984) VAL-030977: |Data flow DF_SAP_0FI_AP_4_Delta|Reader Query-Mapping1
Extractor returned error: <E: MESSAGE - I:RODPS:003 Maximum waiting time of 7,200 seconds exceeded. MESSAGE_V1 - Maximum
waiting time of 7,200 seconds exceeded. E: MESSAGE - Maximum waiting time of 7,200 seconds exceeded. MESSAGE_V1 - 7,200.>.
(14.0) 07-29-12 07:26:20 (E) (93328:9044) VAL-030977: |Data flow DF_SAP_0FI_AP_4_Delta|Reader Query-Mapping1
S
sxu (BOB member since 2012-05-07)
Of course there is.
  • The official documentation contains some references
  • This forum
  • SAP Wiki
  • Google
  • SAP Notes
  • Your own intuition and experience
I have seldom errors that cannot be found with above sources…
If there is a list of what all the error messages mean, I certainly haven’t seen it.
In this case I think the error you want to be looking into is the RODPS:003 error rather than the data services error - The issue looks to be occuring on the ECC side.
Leigh Kennedy :australia: (BOB member since 2012-01-17)
guys, one moment. I am adding a page to the wiki how to figure out missing SAP Notes for ODP. There are notes which contain the text “timeout”.
Edit:
http://wiki.sdn.sap.com/wiki/display/EIM/Installing+ODP+and+keeping+it+current
I don’t know if this is too much to ask, but is it possible to create a master note for all ODP/ECC/Data services related fixes ?
I’d like to be pro-active, but installing full support packs requires full business testing at my company, so we end up having to install each note one at a time. It would be nice if there was one note we could look at each few months to ensure we have the latest fixes.
I had the same thoughts and you probably know that better than I do. But my fear is that this will not be possible as we would need to maintain one master not per ECC Version and EhP and SP, wouldn’t we?
You installed all SAP Notes using the master, 1 year later the SP of the ECC is deployed. This SP does include 90% of the SAP Notes you had installed manually before. If I now add a new one to this master, will it screw up something in SAP?
btw, isn’t installing multiple SAP Notes with my Wiki article easy enough? Am I missing something?
I’ts definitely much improved with your hint, but the sap supplement refers to a note like this, it just isn’t up to date. I take your point that it would get out of date fairly quickly, but given the note is referred to in the docs, maybe update it each Service Pack release ?
Thank you however for your hint - I have already found a solution to an issue we hadn’t even got to logging yet by reading them and i’m only 1/2 way through the list !
Have you made a change to this ? It was working the other day, but returns nothing now !
Update: Its back now - must have been a temporary glitch.
I was already wondering… how can Werner in the early morning from a distance do something with your extractor… :blue:
Not my extractor, the SAP Notes search !
(…via a web conference…)
:lol:
I was thinking about this some more, and I was wondering if there is any logic to the note ids ? We are reviewing all 79, and found we have 30 of them already. It would be nice to know when we review them again in a few months time if we can use the previous higher note number as a starting point. Is that possible ?
