Maximum text chars in box problem
I’m querying an database and displaying a text box in reporter. but its limiting the characters returned to 200.
any idea where i can change this, or am i doing something wrong?
Update: When i click on the ‘view’ button, the objects description, is shown as ‘character’. I have found references to something called ‘Long Text’. so im guessing that the universe designer has declared this as the wrong type ?
Character type = max 200 chars?
cheers
Steve
Mora (BOB member since 2003-06-13)
Did you try a Search? Suggested keywords: long text maximum (I took those words straight out of your question.)
There were a few answers, including this one that tells you to look at the parameters for your universe (well, the designer has to do that) – does that help?
Hi anita, yes i did search with various words, and came up pretty blank…
i must have read about 100 posts at least. !
In the end i deduced that it it because the text is set to 200 chars maximum at the database level.
So i’ve filed an error report and let the server guys sort it.
Thanks anyway.
Steve
