Maximum # of Objects
Is there a maximum number of objects you can include on a query panel? And if so, what is it?
I have a user who wrote a query with 44 objects on the query panel, but BO is bringing back only 28.
We are using BO4.1.2.
Angelia McDaniel
Did you check the slice and dice mode ? It could be having only 28 objects in its panel. I do not know of any limit to the number of objects.
Ashish
If there is a limit it’s much higher than 28. I have users that bring back over 100 objects. Is it just that you only see 28 in the report or are the objects also missing in the “microcube”? If they are just missing in the report add them in the Slice and Dice panel.
If this helps muddy the waters, we had a report that would not bring back all the objects, but when we rolled over to a test WEBI 2.51 environment, voila - the objects started coming back (I think the count was 44 objects before it failed).
Brent
<<Is there a maximum number of objects you can include on a query panel? And
if so, what is it?
