Analytical functions are fixed at run time, you can sometimes use a report level variable with Input output context to define a total, but thats about as good as it gets…
However, its like percentage calculations in SQL, they are only good at run time. You cannot slice and dice them in BO as BO does not support two phase calculations…
Well, well one of my most favorite topics when it comes to BusinessObjects 8)
A) BusinessObjects does support 2-phase calculation, but at the report level (via local report variables).
B) BusinessObjects does not support 2-phase calculation at the universe level alone.
C) With XI R3.0 smart measures were introduced (see also: database delegated), look at those
Smart measures still fall short of the ideal solution, that is: I wish we had the capability to define local report variables, but a global (universe level that is). THAT would be the best solution
Hello Mike, smart measures do require a refresh of the data provider as the measure is re-calculated at the required aggregation levels in the database. That is why it is still not the ideal solution…
