BusinessObjects Board
Max No. of rows that can be used in scorecard
Hi all,
What would be the max number of rows that can be used in scorecard component.
I am trying to map around 2000 rows (35 columns).
I previously could map around 1000 rows & columns and it was working fine.
Thanks in advance.
pranav.c (BOB member since 2015-01-20)
There isn’t a hard maximum. (Well, there might be around the 65K mark, but I don’t know anyone that’s even tried that kind of nonsense.) It’s more of a soft limit. The more rows you put in, the more work Xcelsius has to do. It requires more memory, and performs more slowly. If you have a beefy enough server, you can make 2000 rows work. If not, you’ll start seeing errors.
Thanks Lugh, you are right. 2000 rows are making the dashboard perform very slow and am even getting swf generation error
