Max Date Issue
All,
I need to return 3 pieces of data:
1 - Case No
2 - Date Time
3 - User ID
Several user will access a case but I need to return only the last user on each case. While I can write custom SQL and do a max on the date field because there are many users I will still receive more than one record. While this does not have to happen at the report level it is the preferred option.
Any assistance would be appreciated,
Markus Lowry :us: (BOB member since 2007-03-30)
Is your max only on date or date time ( ie some form of time stamp) ?
I would have though the chances of two users have the same date time on a case would be almost imposssible given time stamp normally goes down to seconds even milliseconds.
Nniixx :australia: (BOB member since 2009-09-02)
Sometimes I cheat Webi like this …
  1. Have your query as Max(Date) AS YourDate, User and Case
  2. Then in your report have a Section on Case.
  3. You then have Case, YourDate and User inside your section. Also a ‘hidden’ column =Max(Date IN Section).
The row where YourDate = Max(Date in Section) is the one you want to show.
  1. Create a variable dimension (MyFilter) that says If(YourDate = Max(Date in Section);1;0)
Now you can create a block filter to only show rows where MyFilter=1.
It will work for some of these sort of queries.
I use this technique when I have to display a summary page (for example one User per Case) and also a detail page (all transactions) in the same report - but don’t want to run two queries.
weaver (BOB member since 2008-10-17)
You want to display the User name those who was opened last time??, right?
then use =CurrentUser() function.
BOCP (BOB member since 2007-07-02)
Nniixx,
Yes there is a time associated with the date.
Weaver,
This option that you provided will not work for my purposes. I need to have a single block containing a single recors for each case having the max date for that case.
BOCP,
I am pulling data from an outside system. The currnet user function that you mentioned is not an atribute in that system. The currentuser function is a BO function that tells you who is working on a document in BO.
Markus
So doesn’t max(date time) give you a single value for each case or do some cases have the same date-time for different users ?
Hi Lowry,
Could you post some sample data with desired results.
So it will be easy to understand the problem and to suggest a solution.
DoSTh :india: (BOB member since 2007-05-31)
Here is an example of the data:
Case# UserID Datestamp
1 user1 1/1/2009 12:01
1 user2 1/2/2009 14:50
1 user3 1/2/2009 16:45
Now because I am pulling these 3 different fields the max date per case number will not work because I get a distinct record for each user that touched the case. I need to only get the final record that will include the case number, the user id, and the tinestamp.
You could do it with a correlated subquery in a dervived table at universe level, but no idea at report level!
Debbie
Here I guess , you need to show two records ?( as per your requirement )-
Please correct me if I am wrong.
Aniket, I think he wants to show all maximums per user, per case.
i.e. the three records he listed.
Agreed, I have no idea how to resolve this on a report… :crazy_face: .
I would always put the correlated Subquery in a filter, infact I discussed how to do this, today, here:-
https://bobj-board.org/t/140568
This keeps your schema a bit more tidy than using derived tables…:).
Thanks for that. I will have a look as it’s something I do quite a lot. I never use filters - I forget they exist!
Debbie
All,
What I am looking fo ris the last user that touched each case. In the example that I provided the report should only return the last user for case 1. This would he user3.
No problem, great for asking questions such as first Order, Last Order e.t.c.
If you use a sequence number in your fact table then you can use this technique to get first record, second record, last record…etc, by defining a series of filters and step through all the history, by a given dimension.
Easy to understand from a users perspective also…:).
So you only want to get back
How about buidling a query with a sub select in it on date eg
select  Case#, UserID, Datestamp
from your tables
where Datestamp in
(select Case#, Max (Datestamp)
from your tables)
obviously the above is a rough guide and may not have the correct syntax.
Hi Markus,
Try with the following custom sql query and let us know…
select x.caseid, x.userid, x.datestamp
from
abc x where (x.caseid, x.datestamp) in (select y.caseid, max(y.datestamp) from abc y group by y.caseid)
Tims_Bo :india: (BOB member since 2008-07-26)
All,
Found an easy way of doing this. I create 2 queries.
The first query contained the case # and the Max(datestamp).
The second query contained the case #, datestamp and the userid.
I merged these two queries in the report and then used the Case# and Max(datestamp) from query 1 and added the UserID from query 2. While this may not be the best way it if functional.
To everyone that chimed in, Thank you for the assistance,
No, you wanted to solve the problem on the report, glad it worked for you… :yesnod: .
Thanks for letting us know what you did…
