How do I get the most recent date BEFORE the UserResponse date entered? Thanks.
curious1 (BOB member since 2008-08-29)
Not sure how (or if) to do this from the universe level but this code should work for you at the report level (You need to update with your prompt);
[list]=RelativeDate(ToDate( UserResponse(“Enter The Date:”);“MM/dd/yyyy h:mm:ss a”) ;-1)[/list]
Joe Szabo (BOB member since 2002-08-19)
Thanks for the suggestion. This variable in the report gets a #ERROR. I have checked the input date data type and the column values, and they match the variable’s data type. Any ideas why I get this error? Thanks again.
=RelativeDate(ToDate( UserResponse(“Enter The Date:”);“M/d/yyyy h:mm:ss a”) ;-1)
It should be one M, and one d.
Lilly J (BOB member since 2002-08-22)
Thats odd, Im able to get the date to display fine without the error (with either my code or Lilly’s). Another bug
XI3.1
Correction - Possibly belongs to WebIntelligence Layer forum
