Match Transform Not working properly
I am using a match transform to find the duplicates. I have used 4 fields (Manufacturer ID, Manufacturer Part Number, Material Short Text Description and Dimension) as my matching fields for Materials.
Earlier, it used to work perfectly fine. But since last 1 week i am facing a weird issue. The records are getting matched only on 2 fields (Man. ID and Description), all the 4 fields are not being considered.
Please note that there is no code change.
I just took the code from central and ran it and this happened. I checked all the possibilities. I added a new match transform and started the matching process from the start but no luck.
Please provide your suggestions! Is it something wrong with the match transform? Do I need to raise a OSS note?
Vijay B
sapds567 (BOB member since 2015-08-10)
