Hi, I am using match transform to identify duplicates in my source data input table. The matching is simply performed on a single column that contains the firm name. I have used base_match transform and within the editor, used standard ‘firm’ matching scores/ values in the ‘Option’ tab. My match criteria is set to 101 and no match criteria is set to 77.
However, for 2 records that are 100% similar, they have not been detected as the same group number for some reason. Irrespective of the match score that I set, the group number column has all blank values for all records…
Is there anything specific that we need to set in order to make sure that we atleast get 100% similar records identified as matching records?
Ankit J (BOB member since 2013-03-14)
(BOB member since 2009-04-30)
