I have scenario where we need to have 600000 records in a group so that users can search for records and group them together based on their tribal knowledge.
IS was throwing error and wouldnt create a task for that match configuration, so we splitted them in chunks of 30k each to accomodate and resolve that issue. Now that we have them in IS we are not able to approve that group of 30k records.
Does IS has limitation on how many records need to be there in a particular match group to be approved?
It does seem to have a limit in prior releases and there are patches out to fix the problem in using match groups > 500k. May be the sap note 2151032 helps you there. An extract of the note is below :
