Marquee Text Scrolling
Hi. I am using Webi 4.2 SP5 and I cant seem to get the marquee text scrolling to work. I have tried the below codes but on both occasions I just get static text with no scrolling. Any help would be appreciated. I have a sneaky feeling this doesnt work with SP5…
These are the codes I have used
="<marquee direction=right
onmouseover=this.stop();onmouseout=this.start();>This is a marquee"
And
=""+[Test] +""
kbanalytics (BOB member since 2019-02-19)
Is the cell formatted to read as html?
Hi thanks for your swift reply. I can confirm it is set to read as HTML
Just to confirm this has now been resolved there was a setting in the CMC that had disabled Javascript and HTML that needed enabling
Thank you for letting us know. :+1:
