Mandatory prompts followed by Optional Prompts
I have requirement where the mandatory prompts should come first and then followed by Optional prompts in a report.
Is it possible to implement this?and how?
Ab
biswalamar (BOB member since 2006-01-04)
Check the query properties - you can reorder the Prompts here.
HTH
NMG
When you generate the Query panel for the report, put the Mandatory Prompts first followed by your Optional Prompts.
This may work for you.
yourajai :india: (BOB member since 2011-03-09)
