The add on manager in Xcelsius 2008 not working properly in Vista environment.
whenever i try to click on add-on manager the system will be restarted automatically.
Finally i installed CX 2008 on Vista and tried to replicate the issue, i get kicked out when i try to access Add-On manager. Im Trying to play with security settings right now. I will let you know if i have a fix.
I disabled the UAC (User access control) and it started working fine. You might also give it a try and let me know. Below is the link to the article on “How to Disable UAC in Windows Vista”
Centigon Solutions has released components for Xcelsius 2008 that provide robust functionality and fill in some of the product gaps. I pulled the link out, as I crossed that line between sharing info and advertising, and I apologize for that. There is a Google Maps plugin on their site that is a free beta that is definitely worth checking out.
