Making into a Prompt
Hi all
I have a date field which is either populated or not populated (blank). Is it possible to make
field into a Yes/No prompt for the user. So Yes if there is a date entered and No if its empty. So
if the user enters ‘No’ then all entries where the date field is blank are returned.
much appreciated#
Sims
Sims786 (BOB member since 2006-04-04)
