Hopefully I am overlooking a simple property, but I can’t find a way to slice and display the data by different granularities in the same graph.
Namely, I want to a vertical mixed graph to have data points for each minute, but I only want the horizontal axis to display labels for each hour. That way, for a given day’s data, there will only be 24 “hour” labels going across the bottom of the graph as opposed to 1440 “hour: minute” labels.
I see something called Automatic Frequency and Frequency for the Y axis on a 2 dimension graph in Webi. Perhaps uncheck Automatic Frequency and set Frequency to a higher number, such as 24.
I did a search on automatic frequency, and this should help:
