BusinessObjects Board
Macro EXCEL documentation for Universe Designer 4.0
I’m looking for in google an excel macro documentation for Universe Designer 4.0, but i dont found.
Can you share the file comment below?
Cerussi
fcerussi (BOB member since 2009-01-27)
Have a look here
BoB is your friend :mrgreen:
[Moderator Note: Moved from General Discussion to Semantic Layer / Universe Designer]
You may need to change the library references. Most scripts that I have written for Xi 3 work for BI4 as long as I update the version of the Designer library that is included. Note, however, that this will work only for Universe Designer universes (.unv files) and not for IDT created universes (.unx files).
Hi Dave,
I try run this macro in BO4.
I change the library according attached file, When I try run “Load Univerve” facing this error:
“Object variable or With block variable not set”.
If I run in BO 3.X the macro is work fine.
Can you help me?
Cerussi
You should probably post your question in the topic related to the utility that you downloaded…
