Lumira downloads for BIP 4.2 SP7
I am preparing to install a new BIP 4.2 SP7 installation on a new w2016 sandbox server. I cannot find any downloads for Lumira 2.2 BIP add-on; I only find for Designer and Discovery… I find BIP Add-On for 2.0 SP00 however.
What are the correct downloads that I should acquire to install the latest Lumira with BIP 4.2 SP7?
Your advice is greatly appreciated
darneson :us: (BOB member since 2009-03-10)
It’s just “SAP LUMIRA SERVER 2.2”.
Joe
Thanks Joe,
So under Lumira Server 2.2 I see Discovery (formerly Lumira Desktop) and Designer (formerly Design Studio). So I install Designer on the BIP servers and Discovery on the developers’ client machines? No separate install for the BIP plugin?
There are actually three components:
Lumira Discovery
Lumira Designer
Lumira Server
The first two are desktop installs. The third is server – it’s no longer called “For BIP”.
Thanks Joe, found the Lumira Server piece. It appears to have files for SP00, SP00 Update, Patch 3 for SP00, and Patch 3 for SP00 Update. For a clean install, which of these loads do I need to perform? All 4?
Use “Update” installers if you already have a version of Lumira Server installed; use the non-update ones for a new installation.
They are all inclusive – the latest one will include prior fixes.
