I have posted this in SCN…may as well try it here too
http://scn.sap.com/thread/3965622
calleT74 (BOB member since 2007-03-30)
I’d suggest you are more likely to get an answer if you post your problem in full rather than a link to somewhere else
Nick Daniels (BOB member since 2002-08-15)
Thanks Nick,
[posted in SAP SCN too]
not sure where to post this, but forgive me if this is not the right place to raise this.
I have a user who had Lumira 1.29.3 installed on his machine and we recently had his version upgraded to 1.31. Now, with all the new features and functions introduced there are a few things that doesn’t look or seem right. Brief list below;
Esri Geo maps - user is still prompted to provide details for an Esri account when try to use a Geo map. Options in the preferences section doesn’t give him the option to chose “Esri ArcGIS Online” --> result: cannot use Geo maps even though it is meant to be free (seen this on only another user)
versions after 1.29x the tab has been removed. I have attached a screenshot of what this user sees. You can clearly see there are 4 tabs visible???
Burning question to the community…anyone else seen this or these types of behaviour? As this sits in the business, everything is always urgent Hope to hear from anyone of you soon. Please help
Cheers
One thing to check is the persons licence - do you know what licence they used to have and that it thinks the licence I still the same ?
Al.
Botfield77 (BOB member since 2016-10-04)
It is not a license issue. One of the first things we checked
