Hai all,
i am facing one client issue
actually lovs created
those lovs working in deski and its not working in webi
please provide me some information.
cheers
MS
ms_dwh (BOB member since 2006-05-17)
Hai all,
cheers
MS
[Moderator Note - edit your post to include a meaningful title, you are more likely to get a response!]
Nick Daniels (BOB member since 2002-08-15)
Did you save the changes and export the universe to the repository and then try refreshing the Web-I document?
Jansi (BOB member since 2008-05-12)
customized lovs is not working in webi but its working in deski
please proved me the some information
LOV lists is not displayed in WEBI.
When we drag any object in the Query Filters pane and ask it to display the LOV list, it does not bring anything back. It’s just an empty list.
Do you have any ideea ?
cheers
MS
So you said in your previous post.
Please do not bump your post until at least one business day has passed.
still i am facing above issue
please provide some good inform
webixir2
Try to recreate and export it again…by the way , when LOV showed up a blank list in webi, did u try to refresh it there? was it still blank?
RBO (BOB member since 2006-08-26)
yes i did same thing then also it showing same blank
i created one fliter in universe level ,
But when the same filter is used in the WEBI report, i get ProcessDPCommands API error.
its working fine in deski
cheers
rajesh
jansi&RBo,
how to solve above problem
cheers
MS
ms_dwh, please do not bump your post until at least one business day has passed.
If you have not already done so, apply SP5.
It resolved a similar problem recently, which occurred on BOEXIR2SP2
jiwilson (BOB member since 2009-07-16)
You should also check you are running a supported version of Java :).
Mak 1 (BOB member since 2005-01-06)
