LOV not sorted in Infoview
BOXI, Release 2
I have a date field which sorts fine (in descending order) in DESKI, but when I run report through Infoview, there is no sort. How can I get a descending sort in Infoview just like DESKI…
ldcaudle (BOB member since 2005-10-04)
Hi…
Can you force the sort by editing the LOV in designer and adding a sort to the date object , or have you done this already and Infoview is just not behaving ?
richmona :australia: (BOB member since 2003-04-15)
I went to the object properties, and edited the sort order for the LOV and it is not behaving in Infoview - just DESKI
Hi…
one other thing. did you check the property of the object in designer to set “export with universe” ?
if you have and it still doesn’t work, and if the field is actually stored as a date field in the table, then I have nothing more to suggest other than contact BO support
good luck
sorry, forgot to addd
check the option “export with universe” and then export the universe before testing the Infoview report again
That was it!!! Thanks!
