LOV in the universe is not recognized by a dimension
Hello,
I have a dimension and a LOV associated to it. This dimension is not recognizing the associated LOV. Below is the SQL from the LOV
SELECT
distinct dbo.v_ilob_fact.niin, max(dbo.v_ilob_fact.backorder_quantity_total)
FROM
dbo.v_ilob_fact
WHERE dbo.v_ilob_fact.niin IS NOT NULL AND dbo.v_ilob_fact.file_date = @Prompt(Date)
GROUP BY dbo.v_ilob_fact.niin
ORDER BY 1 ASC
Limit 100
I am using MySQL
Your query for the list of values is returning 2 columns. When you associate the list of values to the dimension, you need to specify which of the columns joins to the dimension. Something like the attached:
I have done this.
It looks like my previous screenshot was cut off. When you click on the ellipse (…) by the List of Values, you should get an option to assign a column to map.
check if there are values in return by this prompt
“max” is guessed as the name in lov-mapping, because there is no clear column-name in the sql-output
→ add a name in your sql-statement, e.g. max(dbo.v_ilob_fact.backorder_quantity_total) as max_quantity
