Losing Formatting In Excel
I have an object [Weight]. In the universe it’s defined with a format of percentage.
When I put it in a WebI report it displays as a percentage. As it should do.
When I pull that table from WebI to LO (BI 4.0) it displays as a decimal.
I have Permanent Regional Formatting set to “On” on the WebI report.
I have “Insert report part with report format” checked under View in LO Options.
I have “Apply report format when refreshing” checked under Refresh on Live Office Object Properties.
What’s causing this?
Damocles
Damocles :uk: (BOB member since 2006-10-05)
This screams Bug. Remove the universe formatting, it should be decimal in LO? Now add the formatting in the report, such that in WebI its a percentage. Does LO still get it wrong?
Yes, it does.
Buggity.
