I’ve tried google and searching the site but can’t find an answer to this
when logging into reporter , supervisor or designer, either from the client pc or the server using the full client tools - it takes ages to log in, once I am past the login screen, today it’s taking users 40 minutes, its normally around 7 minutes.
here are the systems details and back ground
Running Business Objects 6.1b (6.1.021.2263)
Repository = SQL Server 8.00.760
Server = Microsoft Windows 2000 Advanced Server
Version 5.0.2195 SP 4 build 2195
VMware Virtual Platform
X86- based PC (4x processors)
this system was virtualised this year, and is not the cause of the login time issue as this has been happening for years I am told…
system originally set up to be an infoview server only, and has only 4 or 5 users, but due to a server move and other hardware issues the users now connect via 6.1 fullclient tools rather than via the webi tool…
There is no way we can turn the infoview system back on (we’ve tried)
and when the infoview service was working it used to log in straight away!
I believe this issue is related to the way the system was setup to deal with infoview requests/access rather than directly from the clients pc via odbc connections and sqlserver drivers which is what it is now doing, but what’s causing the delay when launching the application?
Additionally if you use an incorrect password or username you will get an instant error from the login screen, but use a correct combination you get the busobjs weclome splash screen for 40 minutes before the application then responds with the ritual “new report wizard”
please help, I have no knowledge of installing or repairing the 6.1 verson, especially the webi application.
abductee (BOB member since 2006-09-05)
