I hope the following makes sense. In CDD2013, I want to have two chart tabs controlled by the same controls. So, as it were, the controls would be on a “locked” tab which remains visible at all times, with viewers able to toggle between the two chart tabs. Is it as simple as resizing the two chart tabs or is it more complicated than that? Thank you in advance.
Jon
[edited, removed huge font size and color. Thanks, Andreas.]
jonesse (BOB member since 2010-06-20)
