Lock out users?
 Hi all,
 Am I missing something, or is it really not possible in BO 4.1.3 to
 disable groups of users?  For that matter, it would be nice if changes
 could be applied to multiple users selected using the CTRL key.  We
 have a need to lock users out of the BO apps while the d/b is down for
 maintenance, and there seems to be no easy way to do this.
 Any ideas?
 Thanks...Jason Beard
Jason Beard wrote:
 Hi all,
you are right, it’s not possible, except one by one.
 Any ideas?
Idea 1: You could e.g. temporarily disable the “security repository login” for
that time and disable your users from working in off-line mode…
Actually, it depends on WHICH db is down for maintenance :slight_smile:
Idea 2: if your repository setup is rather simple (not too many universe and
document repositories) you could as well disable the universe repositories from
being used. This can be done for groups. Logging in next time will leave the users
with no “granted” universes. Still there remains the problem of simply refreshing
a report which tries to use the db under discussion.
hope this helps.
Walter
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria
Tel: +43-1-8151456, Fax: +43-1-8151456-21
e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
In a message dated 99-02-20 09:04:07 EST, you write:
 Hi all,
I thought this was incorrect, until I verified it myself. Is it just me? Or
was this possible in an earlier version? Perhaps 4.0 instead of 4.1?
In fact, if you position your mouse over the “disable” button in Supervisor
you get a tooltip that says:
Disable/Enable User or Group
So at one time you could disable groups, I believe. Or the intention was
there to have that feature included. I am quite convinced that we used to be
able to do this. Does anyone else remember this? Or am I just crazy?
Dave Rathbun
Integra Solutions
www.islink.com
I don’t think it’s just you. You can also go into Group Properties and
you’ll see a greyed out option to “Disable all group users logins”. If you
pull up on-line help for Group Properties, it says “Disable all group users
logins: No longer available.”
Erich Hurst
Compaq Computer Corporation
