I need to know the location to place the file for the last but one parameter (Request Format) of the Adapter Operation configuration screen for “Put Request/Acknowledge using queues”
I thought that perhaps it was referencing an already imported XSD. Perhaps the referenced file needs to reside on the job server?
Anyone able to enlighten me?
Thanks in advance.
P.S. The DS Documentation is not of much help with it’s description of this field.
enter the complete path of the XSD including the xsd file name
the xsd file should be on Job Server where JMS Adapter is configured
Adapter will read this XSD file and send it to Designer when you import the put operation metadata and store the schema in Repo which will be used at run time by the job
