system
1
Hello
I am trying to load data fixed asset data into ECC using bods.
I keep on getting the following error message :
Asset & & not in company code &
It seems as if the Idoc is using the update mode. Where can one change from update to create?
Thanks in advance.
Extreamrav
(BOB member since 2011-08-23)
system
2
You need some Functional guy to help you if you are new to SAP. Looks like the data is not in the ‘check table’.
BODSDW (BOB member since 2011-01-19)
Hi All
I did find the solution for this.
Extreamrav
It would be nice to also share your solution in case someone else hits the same problem and ends up here after Googling
ErikR
(BOB member since 2007-01-10)
