Load Millions row using RFC enabled funtion
I have tried to laod Onelillion record to laod in SAP CRM using Custom BAPI -RFC funtion, and got loaded all in 3 hours.
But now it is not working that way and it is running from two weeks.
Can you pls guess what may go wrong??
is there any parameter we can set,s o it can accelerate the process.
All I know that about one parameter at datastore level, which allows us to execute thing in batch mode. Currently which is set.
sjain :india: (BOB member since 2009-04-17)
Can you show the monitor log so we have something to start with?
Same bapi, same server, same load on the server, same data? Same release of SAP?
1 mil in 3 hours sounds like a BAPI directly writing to a table to me.
This is SAP Functional Module, calling in BODS.
Funtional module is changed for field length. and performance degraded.
Data is same.
for monitor logs. pls see the attachment.
Please vote and comment
DS - Ability to direct write to ABAP tables.
https://ideas.sap.com/ct/ct_a_view_idea.bix?c=34503CB9-F213-4EF9-8603-E500CB16D712&idea_id=2F931BA4-3B5D-472E-BDDF-7689E33B47C8
bmvrus (BOB member since 2011-05-08)
