LiveOffice BO 4 - Open from Repository not possible
Dear LiveOffice Experts
We are currently planning to switch from our current environment to BO 4.1. In order to switch without any problems we are building a sandbox system at the moment.
The problem now is that I can’t open a report from the repository (the button is greyed out). I read in the forum that this is normal behavior and for first time use a import wizard windows from the left should be started. The problem is, that this wizard window does not even appear. He seems to log me in without a problem, but the window does not show up.
We are using Microsoft Office 2010 and Live Office 4.1 SP 2 Patch 3. The application options are correct (Web Services URL http://.:/dswsbobje/services/Session)
Any ideas on how this problem could be solved?
Thx
lake_bi
lake_bi :switzerland: (BOB member since 2013-05-22)
I always get this error when I try to isert a webi document (Open from repository is greyed out).
ERROR 2014-03-26 12:08:19,781 [8076]: CrystalAddin object is in wrong state.
Maybe the whole Debug log helps somebody to get an idea what the problem could be.
DEBUG 2014-03-26 12:08:19,764 [8076]: log on information: WebServiceURL: http://:8080/dswsbobje/services/session, CMS:
DEBUG 2014-03-26 12:08:19,765 [8076]: show insert wizard dialog.
DEBUG 2014-03-26 12:08:19,773 [7892]: Ping thread starts
DEBUG 2014-03-26 12:08:19,773 [7892]: Enter the Session Ping Loop
DEBUG 2014-03-26 12:08:19,781 [8076]: start Reset autoResetEvent
DEBUG 2014-03-26 12:08:19,781 [8076]: autoResetEvent Reset
DEBUG 2014-03-26 12:08:19,782 [7892]: start closing autoResetEvent
DEBUG 2014-03-26 12:08:19,782 [7892]: autoResetEvent Closed
DEBUG 2014-03-26 12:08:19,782 [7892]: Exit the Session Ping Loop
DEBUG 2014-03-26 12:08:19,782 [7892]: Ping thread exits
DEBUG 2014-03-26 12:08:19,782 [8076]: exit show insert wizard dialog.
I simply want to see the insert wizard dialog. But I don’t have an idea what the problem could be.
Kind regards
Lars
Hello,
Were you able to troubleshoot this?
I am having the same issue Live Office Insert Wizard is not coming up after logging in.
I am also on LO 4.1 SP3 Patch1.But this issue is happening only when I am trying to access LO through Citrix application, but LO installed on my machine is working just fine. :hb:
Let me know your findings.
thanks
romanb4u :us: (BOB member since 2005-11-02)
