live office excel to Explorer problem
Hi everyone
i am facing this issue:
when i send an excel sheet to the Explorer server i get this error
Basically Explorer does not recgnize the comma as decimal separator
(italian standard).
I switched the coma and dots in the windows control panel and it works,
but i’m here to ask if there is some way to change it in BO
since i can’t change it in all users pc.
I also tried to change it in the excel but doesn’t work
Can anyone help?
Thanks in advance and regards
Adriano
adrianox1 (BOB member since 2012-07-14)
Hello,
I’m facing a similar problem. I’ve installed LiveOffice (Version 4 SP6 P1).
When I load some objects from a universe to Excel and then try to put this into live office, I get the attached error message.
What I have selected from the universe are just two objects, technology (string) and netsales (numeric). Its two columns and about 15 rows.
Anybody an idea?
stefan :de: (BOB member since 2008-05-30)
