Listing default settings for reports.
Hi all,
Does anyone know how to list the default settings for reports?
For example, I looking to build a list that has :
  • report name,
  • output format (deski, excel, pdf, etc)
  • output destination (inbox, file location, email).
  • destination options (email info, file location info, etc).
  • notification information
  • recurrence information
If nothing has been built can anyone direct me where to look. If I’m able to, I’ll build it and if I can get it to work will be happy to share on BOB.
Michael.
Michael Abelha :australia: (BOB member since 2002-08-16)
Dear Michael
Have a look to the BOBdownload’s area there are few stuff to document scheduled jobs…
Found it. :smiley:
version 3 of “instance status” is just the thing I was after. Had to tweak it to run in XI3.1 and it gives me exactly what I was after.
This takes you to the file needed.
https://bobj-board.org/t/111635
The following page of the above thread gives you the info to amend the code to run in XI3.1.
Thanks for the help.
