BusinessObjects Board
List of all folders on system and any objects inside them
I apologize if this has been discussed on BOB before but I was unable to find a related discussion.
Does anyone know of a way to get a list of all folders on the system as well as any objects inside of those folders? Just some way to dump this information into a spreadsheet in a format similar to this:
Folder1
Object1
Object2
Object3
Folder2
Object1
Object2
Object3
I tried fiddling with the Query Builder for a bit but haven’t made a ton of progress. Thanks in advance.
clarence (BOB member since 2005-11-18)
Possible with Repository Database retrieval of objects.
Nirav
nniravv :india: (BOB member since 2007-08-16)
Till certain extend, this might can help you…
