Linking two reports(Hyperlinking)
Can someone provide detialed steps to create links between two reports in BO XI R3 for oracle database 10g.
I searched this forum for related topics to find out what i need but couldn’t find any…i thinck i am missing something…pardon me for my ignorance…
If someone can provide some steps to create the hyperlinks or atleast provide me the links which has the procedure, that will be great help…
I am in analysis part of my project and i am preparing documents for my client…
Please help…
Achilies :india: (BOB member since 2008-12-04)
This has the syntax and the explanation. Other than that B :mrgreen: B has lots of topics on the same. Please go through them and come back with specific queries.
P.S: As you’re in XI 3.x, you can also go for a GUI feature where you need not type code for linking documents. Check this topic for more information.
Thank you Jansi, Very Usefull information…
And, Is linking two report tabs different from linkint two documents…
My requirement example:
If i have a document with two report tabs,
one tab contains the deptno and deptname and other report tab contains the empname, empno, sal.
If i click on deptno in first report tab it should take me to the employees page of that deptno which are in second report tab.
Can someone shed some light on this topic…
Thanking you in advance…
Check this topic and see if it helps you.
And also this.
Thankyou Jansi, I think this gonna work for me…
I will test these steps and will let you if its working…
Thanking you :slight_smile:
