BusinessObjects Board
Linking point on BO dashboard to webi
I would like to click on a point on a dashboard and then launch a webi report. I have a link but I would like it to be the point that I hit. How would I do this. Thanks in advance
bernisstewart (BOB member since 2013-11-01)
[Moderator Note: Moved from WebIntelligence XI to Xcelsius - Crystal Dashboard Design]
Use the URL BUTTON component together with the OPENDOCUMENT function. The syntax of OPENDOCUMENT varies according the the version of Bobj that you are running, but if you search in this forum and the webi forum on this site, there are lots of posts on it.
Debbie
