Hi all,
I have a requirement where I’ve to link two Dataproviders based upon one dimension object. One Dataprovider is pointing to Access and another is pointing to ORacle.If both the dimension objects are equal then only the report has to execute other wise it has to raise an eror message ‘Wrong Data’. But I’m unable get the data from these two dataproviders. Please help me out as soon as possible.
Thanks in advance.
Have you tried created two separate blocks from two data providers and see whether they are showing data?
Idea is to make sure both of your DPs are fetching data from the database.
He doesn’t even have to do that. Just do a Data - View Data - and look at the Results tab for each query. That shows you the raw results for each data provider.
As Steve said it does not do it, all it does is show the new result set highlighted in blue, and all you need to do is drag those highlighted objects into the report.
Thanks all,
I’m able to see the data in two dataproviders seperately, but I didn’t find the combination of both.
Like if I’ve 1 st dataprovider query like
SELECT Year,sum(Quantity_sold) FROM Agg_yr_qt_mt_mn GROUP BY Year
2 nd data provider query like
select year,today from scott.efashion
1 st query contains data like
YEAR — Qty_Sold
1999 — 50000
2000 — 60000
2001 — 70000
2 nd query contains data–
YEAR — Today
1999 — sysdate
2000 — sysdate
2001 — sysdate
2002 — sysdate
I want the result to be displayed like
In your example,
After linking the 2 Dataproviders using Year, in the slice dice panel drag sysdate into the table1 place it after qty sold.
This should get your expected result.
