linkage dimension detection
Hello,
I received a custom report with several data sources. I was wondering if there exists a summary overview in ‘view data’ to display which variable are linked which other?
keizersoz (BOB member since 2005-12-14)
even though the below report does not give the object linked. You will be able retrive the objects in your report corresponding to report.
KhoushikTTT :us: (BOB member since 2005-02-24)
