system
September 21, 2011, 8:42am
#1
I am trying to create a linear trend line in my line graph. I have tried using the interpolation method shown here: Graphing Linear Trend Lines
However it plots the same points as my graph does which isn’t what I’m after. Just after a nice line like you get in excel. Any help would be appriciated!
Stealth_Locky (BOB member since 2010-07-21)
system
September 21, 2011, 12:33pm
#2
Here is the code I’m using:
=Interpolation([Secondary Headcount];Linear;NotOnBreak;Col)
system
September 22, 2011, 8:47am
#3
Sorry to bump early, but this is for a project that needs delivering tommorow.
system
September 22, 2011, 12:29pm
#4
hi
The interpolation function will either fill in gaps in your data or you can use to forecast a straight line after the end of your data.
There isn’t (in XI3 at least) a ‘add trend line’ option as you have in Excel but you can create manually as described in this article.
AL
agulland (BOB member since 2004-03-17)
system
September 22, 2011, 2:37pm
#5
Thanks Al, really good article. My problem now is that it is numbers of dates eg; 50205 in January 2011 etc.
The guide caters for numbers by numbers, unless i am being stupid.
