LDAP & SiteMinder for SSO
Does anyone know how to apply the SiteMinder settings for SSO? I researched SiteMinder and do not really know how its being used in our environment if at all. Our network team doesn’t know either. Is this part of the BO installation process similar to how Tomcat gets installed?
If you don’t know what it is and your network team doesn’t either, I would assume that you are not using it and so you wouldn’t need to configure anything for it.
SiteMinder is not part of the Business Objects installation. I can’t really tell you any more about it than that. We don’t use it.
Thank you for the response JohnBClark. Does anyone else know? I do not believe LDAP can be authenticated via SSO without SiteMinder, so we need to figure out how to apply it.
