LCM Err in promoting Crystal Report using Dynamic Cascading
I am having one Crystal report developed in CR XI R2 ,it is using one Dynamic cascading prompt.The DB is Oracle Server.
The report is working fine on standalone desktop as well as Dev server .
But when i try to move this report using LCM to Production (Dev to Prod or Dev to Test) it throws error “Promotion failure - Trying to create an object with duplicate name” .
I have gone through LCM document ion and found that we need to select report as well as the BVM or dynamic cascading .I tried this option also but it didn’t work.
Can anyone suggest what i am missing ?
thanks
Nitin
nitin_gem :us: (BOB member since 2008-11-28)
In the destination system, do you have a report with the same name but different CUID. If yes, you can this message. Renaming one of the reports would help
  • Maheshwar
maheshwar (BOB member since 2003-08-09)
there is no report with same name but i am not sure if the Cascading prompt already exist with same name.As there are 1000 Crystal reports in Production so not sure how to check which all existing DCP in the system.
thanks
Nitin
Issue Resolved.
We need to give new connection for Dynamic cascading prompt in LCM.
Actually in Dev DCP was pointing to other prompt group and in Prod it is suppose to another.
So i modified the DCP in Prod with new Prompt group and it worked fine.
Nitin
