LCM BAIR issue
In this forum I reallydont know where to put LCM issue as here its discussion for CMC i put this issue across here…
My isue I have taken an LCM bair file of 340 MB size and while trying to import to another eniv its saying after 20 mins no file selected…
I increased the time out from 20 mins to 60 mins right from CMC…tomcat & in WEB I processing server and also increaeed cache size for the same but still no luck…
If anyone faced tis issue please let me know how to resolve it.
And FYI after changing the setting i restarted every thing right from tomcat to BO…CMS
babu_272 :india: (BOB member since 2010-07-28)
Why don’t you split the BIAR file to universes, reports,… separately?
This separation will help the easy move between the environments with larger BOE content.
Arjun (BOB member since 2008-07-28)
Hi Arjun,
Thanks for your reply …I cant spluit that file right now since I need to re-import the files in the LCM Biar which ios of 2 weeks old in another eniv.
So this is my problem…can you suggest me better solution…
Check if it is possible with another machine.
Or else ,apparently, this may not possible.
But your BIAR file is too big that means lot of BOE objects has been included.
I think very few changes of BOE contents might happen during this period. So it is better create BIAR files again.
What would you say?
Hi Arjun,
New BIAr file creating…there is an issue thats main reason…
any way FYI…I am getting foloowing error
Its giving me no file selected and when i click on details,
I am getting following error…
com.businessobjects.lcm.actionHelper.JobActionHelper.getJobFromFile(JobActionHelper.java:2764) com.businessobjects.lcm.actionHelper.JobActionHelper.performAction(JobActionHelper.java:197) com.businessobjects.lcm.actions.JobActions.execute(JobActions.java:55) org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:419) org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:224) org.apache.struts.action.ActionServlet.process(ActionServlet.java:1194) org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432) javax.servlet.http.HttpServlet.service(HttpServlet.java:637) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) com.businessobjects.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:110) com.businessobjects.http.servlet.internal.ServletLastFilterChainElement.service(ServletLastFilterChainElement.java:30) com.businessobjects.http.servlet.internal.filter.FilterChainImpl.doFilter(FilterChainImpl.java:46) com.businessobjects.webutil.boetrustguard.BOETrustPrepareFilter.doFilter(BOETrustPrepareFilter.java:32) com.businessobjects.http.servlet.internal.FilterRegistration.doFilter(FilterRegistration.java:72) com.businessobjects.http.servlet.internal.filter.FilterChainImpl.doFilter(FilterChainImpl.java:43) com.businessobjects.swd.shared.tracelog.TraceLogScopeFilter.doFilter(TraceLogScopeFilter.java:38) com.businessobjects.http.servlet.internal.FilterRegistration.doFilter(FilterRegistration.java:72) com.businessobjects.http.servlet.internal.filter.FilterChainImpl.doFilter(FilterChainImpl.java:43) com.businessobjects.sdk.actionfilter.WorkflowFilter.doFilter(WorkflowFilter.java:45) com.businessobjects.http.servlet.internal.FilterRegistration.doFilter(FilterRegistration.java:72) com.businessobjects.http.servlet.internal.filter.FilterChainImpl.doFilter(FilterChainImpl.java:43) com.businessobjects.swd.appcontext.RequestInitFilter.doFilter(RequestInitFilter.java:26) com.businessobjects.http.servlet.internal.FilterRegistration.doFilter(FilterRegistration.java:72) com.businessobjects.http.servlet.internal.filter.FilterChainImpl.doFilter(FilterChainImpl.java:43) com.businessobjects.http.servlet.internal.BundlePathAwareServiceHandler.serviceHelper(BundlePathAwareServiceHandler.java:235) com.businessobjects.http.servlet.internal.BundlePathAwareServiceHandler.service(BundlePathAwareServiceHandler.java:197) com.businessobjects.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:248) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) org.eclipse.equinox.servletbridge.BridgeServlet.service(BridgeServlet.java:220) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) com.businessobjects.pinger.TimeoutManagerFilter.doFilter(TimeoutManagerFilter.java:159) org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852) org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) java.lang.Thread.run(Thread.java:619
Try with different machine, with administrator id.
Are you able to create the Webi reports in
Infoview without any error?
I tried with Administrator ID… and also tried in another systm also…but no luck? :hb:
Ok,
1)Are you able to create the Webi reports in
  1. What is the BO version,FP,OS, etc…?
  2. Did you update your java, BO recently?
In the current eniv is of BOE there is an issue and the services are not up hence cannot create the reports in the eniv where the reports are there i.e from the LCM BIAr hwere i took the back up.
2)THE BOE version id BI 4,0 SP2 and OS is Unix
3)No…
