Label Screen
When you create a new report from the wizard, you can choose mailing label wizard. After the table / fields are chosen you then get to the label screen.
I need to change the label dimensions, so is there a way of getting back to the label screen after the report has been created?
How do I add other labels templates into the pre-chosen label types?
Is there a way to chose/use the mailing label report when it is a sub-report instead of the standard subreport?
zilly (BOB member since 2007-06-18)
Ahh figured out the label dimensions… click selection expert, click details, and then under the tab layout will have the dimensions (needs format with multiple columns selected)
Still need the other two questions though…
