KTEXT , LTEXT, MCTXT
How can we see following fields in Data Services - Table Metadata window
KTEXT
LTEXT
MCTXT
It can be seen using Data Browser in SAP .
sjain :india: (BOB member since 2009-04-17)
By opening the imported table?
We are able to see all the fieds that we can see using Data Browser in SAP except KTEXT , LTEXT, MCTXT.
Therefore, KTEXT , LTEXT, MCTXT can found in Data Services imported metadata.
I believe I know the misunderstanding. When you are in the tabel browser of the SAP GUI (/nse16) this transaction shows you additional columns as well. Look at the table structure of your table (/nse11), you will see there are no such columns.
example: When you view MARA, the Material Text is shown. But there is no such column in the table, the text is in the MAKT table.
