Hi Guys,
I have some bad issues with configuring Kerberos for Java application, I have looked through the other posts and have not been able to find a resolution…
When trying to connect the Java Infoview the following message displays:
Account Information Not Recognized: Internal Error
Looking at the logs the error in the jce_defualt.log is as follows:
<log4j:event logger=“com.crystaldecisions.sdk.occa.security.internal.LogonService” timestamp=“1270658766292” level=“WARN” thread=“http-80-Processor23”>
log4j:message</log4j:message>
log4j:throwable<![CDATA[com.crystaldecisions.sdk.exception.SDKServerException: Failed to contact the Active Directory server.
cause:com.crystaldecisions.enterprise.ocaframework.idl.OCA.oca_abuse: IDL:img.seagatesoftware.com/OCA/oca_abuse:3.2
detail:Failed to contact the Active Directory server.
The server supplied the following details: OCA_Abuse exception 10505 at [.\exceptionmapper.cpp : 79] 50045 { , , secWinAD}
…Failed to contact the Active Directory server. Plugin error: SecWinAD Error: an error occurred in CAccountEntity::InitFromSid().
at com.crystaldecisions.sdk.exception.SDKServerException.map(SDKServerException.java:107)
at com.crystaldecisions.sdk.exception.SDKException.map(SDKException.java:196)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.doUserLogon(LogonService.java:687)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.userLogon(LogonService.java:629)
at com.crystaldecisions.sdk.occa.security.internal.SecurityMgr.userLogon(SecurityMgr.java:223)
at com.crystaldecisions.sdk.framework.internal.SessionMgr.logonEx(SessionMgr.java:678)
at com.businessobjects.clientaction.shared.logon.LogonUtils.logon(LogonUtils.java:85)
at com.businessobjects.clientaction.shared.logon.LogonAction.logon(LogonAction.java:343)
at com.businessobjects.clientaction.partner.shared.logon.PartnerLogonAction.logon(PartnerLogonAction.java:185)
at com.businessobjects.clientaction.partner.shared.logon.PartnerLogonAction.handleLogon(PartnerLogonAction.java:211)
at com.businessobjects.clientaction.partner.shared.logon.PartnerLogonAction.perform(PartnerLogonAction.java:399)
at org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1787)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1586)
at com.businessobjects.webutil.struts.CrystalUTF8InputActionServlet.process(CrystalUTF8InputActionServlet.java:32)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:510)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at com.businessobjects.webutil.websessiontimeout.WebSessionTimeoutFilter.doFilter(WebSessionTimeoutFilter.java:161)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Caused by: com.crystaldecisions.enterprise.ocaframework.idl.OCA.oca_abuse: IDL:img.seagatesoftware.com/OCA/oca_abuse:3.2
at com.crystaldecisions.enterprise.ocaframework.idl.OCA.oca_abuseHelper.read(oca_abuseHelper.java:106)
at com.crystaldecisions.enterprise.ocaframework.idl.OCA.OCAs._LogonEx4Stub.ContinueLogonEx4(_LogonEx4Stub.java:147)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at com.crystaldecisions.enterprise.ocaframework.ManagedService.invoke(ManagedService.java:424)
at com.crystaldecisions.sdk.occa.security.internal._LogonEx4Proxy.ContinueLogonEx4(_LogonEx4Proxy.java:98)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.doLogon(LogonService.java:354)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.doUserLogon(LogonService.java:684)
… 31 more
]]></log4j:throwable>
</log4j:event>
and the message in the stdout.log :
Debug is true storeKey false useTicketCache false useKeyTab false doNotPrompt false ticketCache is null isInitiator true KeyTab is null refreshKrb5Config is false principal is null tryFirstPass is false useFirstPass is false storePass is false clearPass is false
[Krb5LoginModule] user entered username: DWRFIPROVA@T-RFI.IT
Acquire TGT using AS Exchange
principal is DWRFIPROVA@T-RFI.IT
EncryptionKey: keyType=3 keyBytes (hex dump)=0000: 1C F7 3B F8 2A EA 1A EA
EncryptionKey: keyType=1 keyBytes (hex dump)=0000: 1C F7 3B F8 2A EA 1A EA
EncryptionKey: keyType=23 keyBytes (hex dump)=0000: 3B 87 94 EC CE D8 CD 83 F4 0F C0 C0 48 A9 47 8E ;…H.G.
EncryptionKey: keyType=16 keyBytes (hex dump)=0000: A4 AB 8C 3D 3B 43 D5 E3 0E 15 97 A8 E0 1C C8 79 …=;C…y
0010: D0 BC 15 13 DF 52 E6 54
EncryptionKey: keyType=17 keyBytes (hex dump)=0000: 18 16 0F BC E1 4E 98 86 07 FA 99 8C 12 AB 49 4C …N…IL
Commit Succeeded
Very Strange Thing:-(
The kinit commands return no errors and below are the krb5.ini and bscLogin.conf files.
bscLogin.conf :
com.businessobjects.security.jgss.initiate {
com.sun.security.auth.module.Krb5LoginModule required debug=true verbose=true;};
krb5.ini :
[libdefaults]
default_realm = T-RFI.IT
dns_lookup_kdc = true
dns_lookup_realm = true
forwardable = true
[realms]
T-RFI.IT = {
kdc = M-SERVER1.T-RFI.IT
default_domain = T-RFI.IT
admin_server = M-SERVER1.T-RFI.IT
Thanks a LOT
ZAV
zavatta_fighter (BOB member since 2005-05-10)
