Keep drill synchronized with information object?!
Hello,
I have a hierarchy and each dimension has information objects.
Is it possible that the cell, where the information object is displayed will also drill if I drill on the dimension??
So that the drill is not only on the dimensions but also on the information objects?!
Is there a standard function or might that be realized by a variable?!
Thanks for your help!
Joachim
Joachim74 :de: (BOB member since 2005-09-22)
