When running the configuration tool, I end up with the following message: JVM.DLL could not be found at the specified path. Any idea what I should do to solve this problem?
benoit (BOB member since 2003-09-22)
Did you find an answer to this yet? You may just need to define a JAVA_HOME to your jdk/sdk home directory…
For Apache/Tomcat, you also need a reference to this folder, so you may need to check your workers.properties for this line:
worker.java_home=e:\Program Files\jdk
That may not be it, but that is the first thing that comes to mind…
Good Luck,
Brent
bdouglas (BOB member since 2002-08-29)
Did you ever find an answer to this? I’m having the same problem. Please let me know.
Tom
tluskin (BOB member since 2003-07-03)
Hi there,
If there’s a solution to this one I’d love to know it.
This is being a bit of a pain now!
Cheers,
Pete
foshdafosh (BOB member since 2004-05-04)
