Job Opening multiple data base connection pools
I am trying to run a job which was working fine earlier but today when i riun the same job its opening multiple db connection pools and not returning any result set (my source is mysql and target is Oracle).
i am trying to get some data from mysql to insert in to oracle when i run the job its opening 4 pools(in sleep mode) and not returning any results and the job is also not showing any errors and the oracle db timesout after 20 min and then the job is throwing error with timeout from oracle side.
thanks in advance,
Raghu
gandheraghu (BOB member since 2009-03-19)
